Figure out the memory map of RT595 and start address/offset while loading FW into internal PSRAM thr
Mike_Sun
Dear Sir,
In order to figure out the start address/offset while loading FW into internal PSRAM through BLHost based on RT595. Would you kindly advise us what's the start address/offset and how to determine start address/offset based on the FW while loading FW into internal PSRAM through BLHost, please advise us if there is any document to address it. Thank you.
@RossZWChen
diego_charles
Hi @Mike_Sun
Are you using our EVK?
Here is an snapshot of theFigure 2. MIMXRT595-EVK block diagram ( from UM12285
MIMXRT595-EVK Board User Manual)
  I highligthed the PSRAM connections to FlexSPI0 or FlexSPI0.
Are you connecting the PSRAM to FlexSPI0/1?
Thank you!
Diego
