Can't set LPTMR0 for MK60N512DN in PE
rabbit
I can't setup LPTMR0 in PE for MK60D512 MCU, there are a number of lists in Component "Timer", but none is for LPTMR0.
Sam
ZhangJennie
I just have quick test on my side. I use TimerUnit_LDD. there is no problem to set LPTMR0 module here. see below screenshot.
can you please check the same on your side?
rabbit
Thanks. It works for me.
ZhangJennie
you are welcome!
ZhangJennie
rabbit
I try to build a component, but it fails on "Mode ==>Compare",
the list options are "FTM1__  ,  FTM0__, FTM2__".
Please refer to my attached file.
Sam
