CAN_LDD, how to use ?
Search instead for
I hope to use CAN_LDD for CAN bus transceiver, but I do not know How to setting the CAN_LDD component?
attachment is my project, please let me know ...
Kenta
Original Attachment has been moved to: _K60_DN512__CAN_LDD.rar
hello Kenta,
I think you can refer CAN_LDD sample code under {CW10.6 install}\MCU\CodeWarrior_Examples\Processor_Expert\Kinetis\TWR-K60N512\CAN
this answer is for you. if it helps,please click on "correct answer" button. thanks!
Best Regards.
ZhangJun
Hi Jennie,
I see the TWR-K60N512/CAN example project and  modify my project(attached). I want to let CAN0 module to repeat transmit messages and receive messages.
Can you help me to modify or correct my project? Let it to send messages and read messages.
Kenta
Hi Jennie,
I find a circuit on the page 200 AN2865 is good for me.
Is there a MK60 example code like AN2865 ?
and What value is the resistor ?  the power supply will be 3.3V not 5.0V
please ...
Kenta
