Bootloader and EEPROM NVMFlex with K20
1,049 次查看
night
I'm trying to use bootloader with EEProm over NVMFlex memory. The application works fine without the bootloader but when I work with bootloader I can't write on the EEPROM. I just enabled the Partitioning for device register on advanced options in the project menu. The code value used with this is 3303 (for use 2KB eeprom). With the bootloader project I use the same configuration but it doesn't work. Where is the problem?
Thank you and sorry for my English.
          Miguel Ángel.
882 次查看
vfilip
we would need more deatils about the bootloader. Could you please provide more details of the project or in the best case some project how to reproduce it?
best regards
Vojtech Filip
Processor Expert Support Team
