Smart solenoid driver code for "manual" mode 1 DC to DC Vboost generator
Fast
Datasheet says "12.2.1.1 Mode 1 (manual mode)
The DC-to-DC converter control mode 1 is chosen by microcode and is set as the
default. The current_feedback_4 is monitored by microcode and the LS7 is controlled
completely via microcode. The low side is controlled directly by the microcore using the
'sto' instruction."
I can find no example.
Has anyone tried this, as "12.2.1.2 Mode2 (hysteretic control)" generates too fast LS7 at over 2MHz!
Fast
Sure Erika, MC33PT2001HMAE, but this question would also apply to MC33816 thru MC33PT2000.
ErikaC
Could you please open a support ticket to send you the MC33PT2000 programming guide and instruction set
https://support.nxp.com/s/?language=en_US
I cannot share it here.
ErikaC
Could you confirm the part number you are using?
