i got a B4420QDS board, no eth interface seen in the board after bootp with default configuration setting?? Any enviornment parameter needs to change ??
admin
Specialist II
what i did is
just power on the board,
it booted with default configuration, i did not change anything
it came up with an prompt
logged in to the board with root user
then tried to assign a ip to the board
but no Ethernet interface??
yipingwang
Do you use USDPAA dtb? If so, all the ethernet ports have been assigned to USDPAA, so you cannot see them in Linux Kernel.
