how is u-boot address set for PBL to find it
1,910件の閲覧回数
jsanchor
I have a PowerPC P5020DS board. The manual shows u-boot addresses as:
0xEFF8.0000 u-boot (current bank) Size: 512KB
0xEBF8.0000 u-boot (alternate bank) Size: 512 KB
My u-boot image won't fit in 512KB and hence I want to move u-boot, unfortunately i can't seem to find how this is done. I am thinking the Pre-Boot Loader (PBL) jumps to u-boot entry point.
1,845件の閲覧回数
yipingwang
You could refer to Linux SDK 2.0 u-boot source code. Please refer to the following NOR flash memory map in Linux SDK 2.0.
1,908件の閲覧回数
jsanchor
oh, processor jumps to 'reset' vector, and from there (probably) u-boot takes over. I found CONFIG_SYS_TEXT_BASE in u-boot code. I will keep looking, hopefully someone can confirm I am on the right track.
1,846件の閲覧回数
yipingwang
