e500 core revision
已解决
e500 core revision
跳至解决方案
1,869 次查看
benjaminchauvel
i was reading an interesting answer about Application Note AN3532 and CPU30 Erratum : https://community.nxp.com/message/435201?commentID=435201#comment-435201
I'm looking for an official document describing e500 core revision for P2020 so i can do only step 2. 3. 4. and 5 for instruction cache parity error handling ( if i'm correct, I don't want to do a full cache invalidation ) .
An official answer on your forum may not be enough for QA department. Do you know where can i found that information ?
Thanks.
Benjamin
1 解答
1,793 次查看
ufedor
P2020 silicon Rev 1.0 has e500 core Rev 4.0
P2020 silicon Rev 2.0 has e500 core Rev 5.0
P2020 silicon Rev 2.1 has e500 core Rev 5.1
From the P2020 QorIQ Integrated Processor Hardware Specifications, 4.2.1 Part Marking
P2020xtencdr
r - Silicon (die) revision:
A = Rev 1.0
B = Rev 2.0
C = Rev 2.1
在原帖中查看解决方案
2 回复数
1,793 次查看
benjaminchauvel
thank you
1,794 次查看
ufedor
P2020xtencdr
A = Rev 1.0
B = Rev 2.0
C = Rev 2.1
