What is TMRA & TMRB in MWCT1013A ?
JagirMehta
I am new to wireless charging controller MWCT1013A,
From TRM i found that we have 4 timer/counter block.
But while register memory map I found there are 2 different registers  like TMRA_0LOAD & TMRB_0LOAD ? so here what is A & B stands for bcoz we have 4 timers so it will be 4 diff variables "TMRA_0LOAD", "TMRA_1LOAD", "TMRA_2LOAD", "TMRA_3LOAD" only. but I find same series for B also.
Also Can I have API documentation for MWCT family microcontrollers becoz it's hard to understand functionality of each API/function.
xiangjun_rong
Pls download the MWCT1013VLHRM.pdf from the link:
https://www.nxp.com/products/power-management/wireless-power/15-watt-wireless-charging-transmitter-i...
For the MWCT1013, there are two quadTimer module TMRA and TMRB, each TMR has 4 independent counters. In other words, the TMRA has 4 independent counter, the TMRB has 4 independent counter.
Hope it can help you
XiangJun Rong
