I have been using the flash programmer to program a small batch of boards fitted with an MPC8377, using the Codewarrior TAP (ethernet version) and an evaluation edition of Codewarrior. Unfortunately I don't have the budget to purchase the full version of Codewarrior IDE, so I am wondering if there is a standalone flash programmer that can be used with Codewarrior TAP, or at least an API that I could use to write my own programming application.
kind regards
Andrew
解決済! 解決策の投稿を見る。
I am not aware of such standalone flash programmer for PowerQUICC in Freescale.
For budget control, you can purchase only the Basic level CodeWarrior, which is only $395 for annual subscription, it contains flash programmer.
See the price and features supported here: CodeWarrior Development Suites|Freescale
And the evaluation license you could extend at most twice.
I forgot to ask earlier, what happens when an annual subscription expires? Does Codewarrior stop working, or would I know longer be able to receive updates, but be able to continue using an old version?
Andrew
The license expires after the subscription which requires renewal for continue using, which is also $395 with part number CWA-BASIC-R.
See below for how to:
Renewals for the annual subscription suite can be purchased on the Freescale web store, an authorized Freescale distributor or through expiration reminder e-mail.
If you wish to purchase your subscription renewal online through the Freescale web store
| Suite Level | Support Renewal Part Number |
| Professional | CWA-PRO-R or DLA-PRO-R |
| Standard | CWA-STANDARD-R or DLA-STANDARD-R |
| Basic | CWA-BASIC-R or DLA-BASIC-R |
Note: in case you do not have a valid parent ID to apply your maintenance you’ll get this message: You currently do not have an active entitlement to the required software necessary to register this software product. If you have already receive your subscription renewal code through your Freescale distributor do the following
If you received an expiration reminder e-mail from Freescale.com. Click on the option to renew. This will add the maintenance renewal code to your shopping cart, from here do the following:
Thank you for the information.
Thank you for your answer. I wasn't aware of the basic edition, but that will help.
Andrew
