Searching for new MPC8xx development tools
929 次查看
Pierre_Richard_Primma
We have been using Diab (or Diabdata) version 4.3 to compile C code for an MPC885 (MPC8xx) microprocessor for a number of years. For on-chip debug we used SDS75 with an old Blackbird Centronics (i.e. parallel) port dongle from Mcraigor systems. The compiler and debugger softwares were running on a old PC with a Centronics port under Windows XP.
Now, we would like to switch our development environment onto a modern PC under Windows 11 using an USB port to perform on-chip debug.
Which compiler(s), debugger(s) and dongle(s) would you suggest using ?
Thanks in advance.
Pierre Richard
Multitel
1 回复
908 次查看
Chavira
Hello Pierre_Richard_Primma!
We have a compiler compatible with (MPC8xx) microprocessor you can check this compiler following in the next link.
CodeWarrior® Development Suite for Networked Applications | NXP Semiconductors
For the hardware compatible we have the next debuggers.
CodeWarrior® TAP | NXP Semiconductors
USB TAP for PowerQUICC® I | NXP Semiconductors
Best regards!
