We are working on T4240 custom board.
We have run the following code, to check the time taken by process to excecute.
main()
while(1)
time1=gettimeofday();
printf("\r\n time :%ld",time1);
We have observed that the time stamp difference is about 300 ms in regular intervals.
We have checked the kernel scheduling policy between the multiple cores in T4240 and found that it is
"SCHED_OTHER"
Help is requested on the following points:
1. Is the difference in timestamp (of 300ms) due to scheduling of processes between multiple cores?
2. If the difference is due to policy "SCHED_OTHER", how to change the scheduling policy of the kernel to avoid delay in processing.
thanks in advance.
