Power dissipation field - PowerQuiccII (82xx) series - tabular format
2,172 次查看
sathyadevk
When the list of all processors in PowerQuiccII (82xx) series are displayed in a tabular format in the freescale website, there is more than one value given for power dissipation. Example for MPC8260, these values are there in power dissipation field: 3.05; 2.3; 2.62; 2.95; 2.5; 2.2; 1.7; 2.4. How are these values to be read and interpreted? Thanks. Sathyadev
1,981 次查看
alexander_yakov
These numbers are for different core/CPM/bus frequencies. Please look device datasheet, Table 5 for more details.
http://cache.freescale.com/files/32bit/doc/data_sheet/MPC8260EC.pdf
http://cache.freescale.com/files/32bit/doc/data_sheet/MPC8260AEC.pdf
1,982 次查看
alexander_yakov
