Linux driver for UMCC device on LS1043A or similar
3,025件の閲覧回数
SteveMans
Is there a Linux driver for running the QUICC Engine UCC device in UMCC mode ?
We are aware of fsl_ucc_hdlc but we need a driver to run in UMCC mode
7 返答(返信)
2,952件の閲覧回数
Hector_Villarruel
Hello @SteveMans
Regarding your case request,
We do not have a driver available for LS1043A, since we have a few issues on it, nevertheless based on our LSDK, the driver available was originally created for P1021, you can use it as a base for create your own driver or you can contact our paid professional support services at the following link:
https://www.nxp.com/support/support/nxp-engineering-services/professional-support-for-processors-and...
Have a great day.
BR,
Hector Villarruel
2,938件の閲覧回数
SteveMans
How can I get that driver you refer to ?
Is it available on the web ?
2,911件の閲覧回数
Hector_Villarruel
Hello @SteveMans
Regarding your last reply,
This driver is available on the LSDK.
BR,
Hector Villarruel
2,715件の閲覧回数
SteveMans
Thankyou for the reply.
I have looked in the LSDK but have not been able to find anything.
Please can you tell me exactly where the files I need are located, and what they are named.
Many thanks.
2,627件の閲覧回数
Hector_Villarruel
Hello @SteveMans
Hope this post finds you well,
Regarding your last reply:
The drivers are available on the LSDK, I would also like to provide you with the following git where you can find the available drivers at the "drivers "section.
https://github.com/nxp-qoriq/linux
Nevertheless referring to my previous reply:
Please note that we do not have a driver available for LS1043A, since we have a few issues on it, nevertheless based on our LSDK, the driver available was originally created for P1021, you can use it as a base for create your own driver or you can contact our paid professional support services at the following link:
Have a great day
BR,
Hector Villarruel
2,236件の閲覧回数
SteveMans
We have searched in the sdk but we cannot find anything resembling that driver.
If there really is a driver which exists for the P1021, then please can you tell me exactly where the files I need are located, and what they are named.
In other words, what is the actual filename which you are referring to ?
Many thanks
2,993件の閲覧回数
Hector_Villarruel
Hello @SteveMans
This post is to inform you that we acknowledge the receipt of your case,
I Keep working on the solution on this case.
I’ll keep you informed on the process,
Have a great day.
BR,
Hector Villarruel
