I can't find MPC8569E's pin assigned to RMII REF_CLK (TX_CLK) in the datasheet
Search instead for
I'm going to use all MPC8569E's UCCs as Ethernet RMIIs. RMII mode needs REFCLK pin. According to the QEIWRM document, REFCLK function is assigned to the TX_CLK pin. As I mentioned in the topic's name, I cannot find the pin with that name. Please, give me hint where to seek for.
I found the answer on the page 5-37 of the QEIWRM. On the MPC8569E CLK16 can be programmed as common clock for UCC1-8 receive and transmit clocks.:smileycool:
