How to test NVRAM in Yacto Linux
2,532 次查看
vinothkumars
Senior Contributor IV
Hi All,
I am using Power PC and I want to test NVRAM.
1> Is it any commands to test nvram in command prompt ?
2> How to write, read and erase NVRAM ?
VinothS
Vinothkumar Sekar
标记 (2)
2,147 次查看
Pavel
Often u-boot is used for RAM test.
U-boot contains simple memory test.
See the following pages:
https://github.com/LeMaker/u-boot/blob/master/doc/README.memory-test
http://www.denx.de/wiki/publish/DULG/to-delete/UBootCmdGroupMemory.html
Pavel Chubakov
2,148 次查看
Pavel
Pavel Chubakov
2,147 次查看
vinothkumars
Thank you Pavel, I closed this thread now.
Vinothkumar Sekar
