How to Execute A-008109 erratum workaround
4,175 次查看
singhawadhesh
Hi Team,
I am working on T2081 based custom board. I have soldered discrete DDR3L (micron-MT41K512M16) on it.
I am unable to configure and initialize through the QCVS tool.
While debug  found a errata A-008109 (in T2080CE-Rev5.pdf) related to soldered discrete DDR3L as:
A-008109: Memory controller could fail initialization with soldered down register and
discrete DRAM
To apply this I need to update DEBUG_19 and DEBUG_29 as input.
Please could you let me know where/which file should I update to apply the changed value.
Thanks and warm regards,
Awadhesh Singh
4,143 次查看
ufedor
Please provide the processor to SDRAM connection schematics as searchable PDF for inspection.
4,170 次查看
ufedor
The erratum is not applicable if there is no soldered down register in the design.
4,160 次查看
singhawadhesh
Hi Fedor Bayev,
I have soldered down register and discrete DDR3L (micron-MT41K512M16) in my custom design.
Would the erratum applicable for this and how to execute this workaround?
Awadhesh
4,144 次查看
ufedor
