How to Configure The UPMA in MPC860T.
1,670 次查看
phani
I have SDRAM on CS1 we configred it for CS1 in .cfg file and we initialized the UPMA RAM array in .cfg file once we added these configurations we are unable to erase the Flash.Our flash is at CS0.May i know how to change the .cfg file for the UPAMA.I have old.cfg without UPMA as previously we mounted SRAM for that we used this cfg file,new.cfg file is with UPMA and SDRAM mounted.We have removed SRAM @cs7 and we added SDRAM@cs1 .
Original Attachment has been moved to: NEW.cfg.zip
Original Attachment has been moved to: OLD.cfg.zip
1,445 次查看
alexander_yakov
The following string in your file is incorrect:
writemmr OR1     0xFE000800 # OR1 - SIZE OF THE SRAM IS 16MBYTEs
Mask 0xFE000000 means 32 mbytes, but not 16 mbytes. So, one extra address line is unmasked and not connected to memory.
1,446 次查看
alexander_yakov
1,445 次查看
alexander_yakov
Please attach old .cfg file (where Flash programming works properly) and new .cfg file with UPMA initialization added.
