Hi everyone, I want to know how to recover the P2041RDB-PB because the u-boot on the NOR flash gets accidentally erased
pabloramos
Hi everyone, I want to know how to recover the P2041RDB-PB because  the u-boot on the NOR flash got  accidentally erased.
Thanks in advance for your aswer
yipingwang
There is an application note AN4267.pdf about how to recover corrupt Flash, which could be downloaded from Freescale public Website.
addiyi
You should use Flash Programmer from CW, import P2041RDB_NOR_FLASH.xml Target Task, Add Program Verify Action, select Erase sector before program and set offset to 0xEFF80000 (last 512K of NOR).
Also, you can take a look at this thread: P1020RDB NOR FLASH PROGRAMMING
Adrian
