Ethernet not working properly
2,179 次查看
jagrati_chaudhary
i upgraded my device kernel 4.1 to 6.1 which use soc LS1020A. after upgrade device id booting properly and Ethernet poet is coming up but when i try to ping Ethernet server using Ethernet  port ping is not going even i am using the same Ethernet port which i use to boot device using tftp boot.
i added my device dts and dtsi file and kernel logs also.
2,036 次查看
jagrati_chaudhary
Is there any way that i can upgrade my device Kernel without upgrade uboot?
2,145 次查看
Oswalag
Hello.
You upgraded to 6.1 but in your log file I see the U-boot version as
U-Boot 2016.09
Please as a first step, upgrade your u-boot  version according to the LLDP version.
