Data Bus Size of SDRAM for MPC855T
981 次查看
takahidenakayam
Equipment with MPC855T CPU has been developed, but we're going to eliminate 1 of SDRAM for production cost reduction and change the data bus width of an external memory to 16bit from 32bit.FEC is being used, but does change in the data bus width influence DMA movement of FEC?
887 次查看
takahidenakayam
Thank you very much for your comment.
We discuss an application notebook.
887 次查看
r8070z
Yes decreasing of the data bus width will influence to DMA movement of FEC and will increase the risk of the FEC FIFO underrun. You can estimate that in way suggested in application note 860T Design Advisory
http://cache.nxp.com/files/netcomm/doc/app_note/AN2064.pdf
