Hello Stacy,
You could integrate open vSwitch into ltib as the following.
Please create a new folder openvswitch in dist/lfs-5.1/, then put the attached spec file in folder.
Enter into /opt/freescale/pkgs/, use wget download openvswitch-1.10.0.tar.gz and compute the md5sum then save it as file openvswitch-1.10.0.tar.gz.md5.
Run ./ltib -c
Select "Configure the Kernel" and "Leave the sources after building".
Select dependent package "openssl" and "bridge-utils".
Build and deploy openvswitch into filesystem.
./ltib -m prep -p openvswitch.spec
./ltib -m scbuild -p openvswitch.spec (build the package)
./ltib -m scinstall -p openvswitch.spec (install the package)
./ltib -m scdeploy -p openvswitch.spec (deploy it into filesystem)
./ltib (generate the filesystem again)
I have do some verification for you, but I didn't pass building openvswitch 1.10.0 with Kernel 2.6.29, I think there should be compatible problem, so more effort is still needed.
If further assistance is still needed, please feel free to let me know.
Yiping
