uja1169 is not allowing me to re flash my micro
omar_chiara
Once I program the SBC(to normal mode) it seems that the watchdog turns off the microcontroller power supply, and this causes that I can't flash my microcontroller anymore, I don't know if there is a way to avoid this and keep flashing the micro normally
KalpeshRamani100901
You can pullup RESET line while programming/debugging either on board or on debugger.
By doing this, You are good to go for flashing/debugging and when you would like to check full functionality, You can remove pullup and SBC will take control over it.
TomasVaverka
Hi Omar,
I would recommend to take a closer at Chapter 12 of the attached AH1306 which discusses this topic in detail.
If still some clarification is needed, please let me know.
Tomas
