Hi David,
Hope you are also doing good.
Sorry for not giving you enough information.. I'm using this Evaluation board with FRDM-KL25Z driving it. But unfortunately FlexGUI for Q100 (XS2410 Extreme Switch) only allows to download x64bit application.
So apparently what you assumed should suit me - actually doesn't as I need config and lib files for Q100.
AJ
I hope all is great with you.
Could you please share more details about the freedom board that you acquired?
Let’s assume that you need to download the FlexGUI for PF8100/8200/8101/8201/8121 Family.
First, please make sure that you download the Java JRE (Java SE Runtime Environment).
Once the Java JRE in installed, run GUI using 'flexgui-app-pf8xxx.bat' file located in 'bin' folder.
I hope this information helps.
David
