Wireless Charging Coil Array Solution?
3,536 次查看
corynrobinson
Does NXP offer a solution for large area wireless charging? More specifically, I’d like to implement something similar to WPC’s B1 coil array. The part I’m having trouble with is coil selection.
标记 (2)
3,266 次查看
reyes
Unfortunately there is no solution in the current NXP portfolio to support 12 coils.
3,266 次查看
reyes
I suggest you to use the WCT1111 in B type (Multi-coil) solution, this way you will use only one chip to control multiple coils.
Please refert to the detali in below link:/external-link.jspa?url=https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fwireless-power%2F1...https://www.nxp.com/products/power-management/wireless-power/15-watt-wireless-charging-transmitter-i...
I also recommend you to review the application note “Migration from A13 to B5 Wireless Charging Transmitter” in the link below, this App Note describes how to design a multiple coil wireless charger with the topology B5, which design has four PCB coils. This transmitter topology allows to connect two coils simultaneously to achieve better charging performance and active area efficiency for the case when the receiver is placed between two coils.
AN5059: https://www.nxp.com/docs/en/application-note/AN5059.pdf
Jose
3,266 次查看
corynrobinson
Thank you for those resources, however, I’m looking for a solution that provides a much wider charging area. B5 only supports 4 coils, but I’d like to implement something like 12 coils.
3,267 次查看
reyes
