I have used MMPF0100F0AZES PMIC in my design. All Power Rails Are Working Fine; Despite VGEN2 & VGEN4.
As per the F0 OTP config, VGEN2 should be
VGEN2 - 1.5V
VGEN4 - 1.8V
But currently, I am getting below voltage as an output.
VGEN2 - 3.2
VGEN4 - 2.65
I have measured this Rails on multiple boards but the result remains the same.
Here I am also attaching the Schematic of PMIC Section.
Kindly let us know where I have done a mistake.
Solved! Go to Solution.
You can add load on VGEN2/4 to test again!
