UJA1169ATK V2 Voltage is abnormal,v2 is 2.5V
IvyGuo
UJA1169ATK V2 Voltage is abnormal,v2 is 2.5V,it’s expect to 5v..I wonder which issue result in the sbc run in abnormal mode,the user mannual seem not to explain which conditions the V2 voltage is 2.5V.
guoweisun
Do you add external load on V2?
IvyGuo
Dear,Sun!
      There is no external load on V2,here is sch.
guoweisun
Can you change other new UJA1169 to test?or how many boards do you test?same issue?
