Supplying power using PMIC for i.MX 6ULZ reference design
4,635 次查看
oscar_duran
Where do I find a reference design that uses PMIC for i.MX 6ULZ?
4,363 次查看
reyes
Hi Oscar,
6ULZ is same silicon as 6ULL, therefore we propose the PF1550.
PF1550: https://www.nxp.com/products/power-management/pmics/pmics-for-i.mx-application-processors/pmic-with-...
We have a schematic that you can use as a HW reference design, see the below PF1550 + i.MX 6ULL reference design, and enclosed schematic in PDF format.
KIT6ULL-1550EVM (PF1550 + i.MX6ULL).
SCH-29464,1.35V LvDDR3
Please let me know if you need more information.
Jose
1,925 次查看
ET_Dev
Hello
Is it possible to share the hardware design files for the KIT6ULL-1550EVM as well?
4,364 次查看
reyes
Hi Oscar,
Jose
4,363 次查看
oscar_duran
Hi Jose,
Thank you fot you answer, an apologise for thed delay.
Effectivelly, the RD that you recomend was very usefull for me.
Have a great day to.
