RDDRONE-BMS772 - connection of 6 battery cells
suvasis
hi,
I bought a UAV battery management system, RDDRONE-BMS772, recently. I don't see clear documentation on nxp's RDDRONE-BMS772 about the connection of cells. Attaching image of cell connections in image 1 and jumper configuration in image 2.
Pls confirm if the cell connections are correct and also the jumper configuration?image (1) (1).png
Thanks.
suvasis
guoweisun
Please follow UM11421 PAGE15-5.2 Cell terminal connection and below picture for reference connection.
suvasis
hi,
Can you pls confirm the cell connection image is correct or not? The documentation isn't clear on the cell connection. Timage (1) (1).png
suvasis
hi,
Can anyone pls confirm the 5 battery cells are connected correctly? I am confused about the negative terminal of the BAT1 and the Board GND if they are really connected to each other?
Thanks.
suvasis
