Parameter of Ringo for UM11725 TEA2017 high frequency design example
tunghung1127
Can provide the parameters of Ringo for UM11725 TEA2017 high frequency design example.
https://www.nxp.com/webapp/Download?colCode=UM11725
thanks
Tags (2)
luckytail
hello,can you help provide the LLC transfomer parameter,thanks
luckytail
AvnetLLC
Hi NXP TechSupport.
I extract parameters and save mif file and paste it xls tool but looks parameters not changed as attached.
In this case should i change parameters by manually?
(TEA2017 design tool. it looks 240W base so i paste 150W(high frequency) mif after extracting it from 150W evk board)
guoweisun
If you use the GUI to control TEA2107 you'd better set the related registers content for suitable your requirement.
tunghung1127
Hi guoweisun
OK! understand.
But if you can provide these parameters for reference, it will be very helpful to tune my board.
guoweisun
Sorry that we also don't have that, you can fill the parameters by yourself.
