Hey, i have board which integrates two fpga's which needs several different voltages.
My main power is 12v
The first is fpga requires 1.2v for core and 3.3v for vccio and the second is requires 1.0 for core, 3.3 for some vccio, 1.0v for serdes core, 1.8 for aux and 1.1v for some vccio (for lpddr)
So i will need buck converters and ldo's for the serdes and aux power. I also need to power lpddr4 which for that i use a ti pmic which requires 5v and input that can be received from my main power.
For now i used lt8653 converters and tps74901 ldo's to power everything but i wanted to know if you have a PMIC to replace all this power system that can fit for my requirements.
Thanks in advance
Hi Michael
What are the loading capability for each regulators your required?
1:For the 5V input I recommend MC34PF8100.
