PF8200 OTP Programming
2,810 次查看
adevries
I'm interested in programming the OTP bits in the PF8200. I saw that it can be done via I2C, but I cannot find an OTP programming specification document for it, and the datasheet says to contact NXP. So how do I accomplish programming the OTP memory in the PF8200?
标签 (2)
标记 (3)
2,583 次查看
bernhardfink
We have a programming adapter for it:  PF8200/PF8100 Programming Board | NXP
This works together with the FlexGUI software.
If you have un-programmed PF8200 samples, then you can use this tool to program the OTP.
The Configuration Reports for our standard types on this site
      PMIC for high-performance applications | NXP
can be used as a guideline for the values you typically need to apply to the FlexGUI software, in order to generate an OTP programming file:
For production purposes, we recommend to use a partner, who can program and test them before they get assembled.
Bernhard.
2,583 次查看
guoweisun
We don't recommend to you do OTP by yourself,you can contact with you local NXP distributors for applying
OTP request then you will get your desire OTP parts.
2,584 次查看
bernhardfink
Bernhard.
2,583 次查看
guoweisun
Thanks!
