PF8100 VSNVS output Impossible Voltage
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
when i modify "i.MX8QXP MEK schematic" to my own imx8qxp board, see attachment,i find VSNVS pin output at 5v, in datesheet VSNVS max output voltage is 3.3v. i do not know where is wrong, thanks for give me some suggesstion!
我在用官方IMX8QXP修改至自己的核心板,主要是简化了不必要的接口电路,原理图见附件,但我板子做回来测量发现VSNVS的输出有5V,而数据手册上最高电压为3.3V,找了很大时间未找出原因,所以求助论坛,非常感谢!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Simplify board to only have pmic part, schematic see attachment,VSNVS also output 5V, Where is wrong
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Do you connect with light load on this VSNVS output then see the actual output?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
when VSNVS load 1k ,the actual output still is 5V
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Do you mind have a phone call with me?
Or give your phone number!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
孙工:
我想用二层板做一块pf8100的测试板,原理图见附件。
在 2018-12-04 13:17:36,"褚立" <chinachuli@163.com> 写道:
HI:
我的电话:18158182825 褚立 非常感谢!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
可以这样做,或者你能预留一个Li-ion battery的位置方便调试,拉出来IIC的信号出来。
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
HI:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This should not PMIC's issue,you can disconnect VSNVS with your system only test VSNVS output to check PMIC good or not.
