PF1550 and I.MX6ULL
PF1550 and I.MX6ULL
1,832件の閲覧回数
_ZZ_
I have a I.MX6ULL design which has PF1550 PMIC device. How do I access the PF1550 registers from the firmware? Like sysfs files or something else
タグ(1)
3 返答(返信)
1,784件の閲覧回数
guoweisun
You can communicate with PF1550 with the IIC registers which had showed in datasheet for full registers value of PF1550.
1,753件の閲覧回数
_ZZ_
I have seen the below PF1550 Linux driver,
https://github.com/nxp-imx/linux-imx/blob/lf-6.1.y/drivers/regulator/pf1550-regulator-rpmsg.c
is there a simple guide how I can port this into my build?
thanks,
1,741件の閲覧回数
guoweisun
You can try to test!
