The PF1510_GUI_x64_Installer fails with error message that no JRE could be found. The requirements do not mention anything about needing a JRE. What version is needed? Will an Open JDK installation work? If so, what setup (reg keys etc. so installer can find the open JDK installation) is required for it to work? Or does this installer and resulting program need some JAVA browser plugin?
You can refer to below for Installing the Java JRE:
www.oracle.com/technetwork/java/javase/downloads/jre8-downloads-2133155.html
(8u162 or newer).
