Maximum continuous output current for NX20P5090 is 5A. Is there any overcurrent protection feature for this load switch? What happens if a short-circuit occur at the output load? Thanks.
Solved! Go to Solution.
There is no over current protection,it used in USB PD terminal if happened on short event,the PD terminal will prevent.
Thanks, Guowei.
