Welcome, please let me know how I can order a chip with my own version of OTP configuration PF8100 and PF8200 from the manufacturer, if your standard OTP configuration options don't apply to me?
There are many OTP pre-programmed options for the PF81 and PF82 PMICs as you can see in Table 2 of the device datasheet: https://www.nxp.com/docs/en/data-sheet/PF8100_PF8200.pdf
If none of these pre-programmed options works for your system and you need a customized PMIC, I recommend you to contact your NXP sales representative or your NXP Authorized distributor and depending on the opportunity, NXP fabric or distributors can make a custom part number with your specific power up requirements.
If you are currently not working with a NXP sales representative or with a NXP Authorized distributor, you can find the contact information in the following link: http://www.nxp.com/support/sample-buy/distributor-network:DISTRIBUTORS
Jose
NXP Semiconductors
