MS35FS6500 3.3V output power Insufficient
erreer
         Hello,I am use ms35fs6500  to provide  power   for mpc5744 ,the ms35fs6500 provide 1.25v,3.3v and 5v for mpc5744p,but the AD of mpc5744p have a big noise,and  i  have  do this :
PMC.PMCCR.B.PMCCR_EN=0b1;
PMC.PMCCR.B.INT_REG_BYPASS=0b1;
 the noise is still  remain, I test all method ,and I find if i parallel a external 3.3v  in my minimum system board ,then the noise is disappear.
The information is  about this:
I use 2 PNP for ms35fs6500, the ms35fs6500 is in debug  mode ,  the exposed pad of ms35fs6500 is not  connect to GND,  and the power dissipation  of the minimum system board  is small , the 1.25v,3.3v and 5v is normal.
why the noise is generate? what should i do?
