MC33879A for new design
Search instead for
I am planning to use the MC33879A for a new design which will be in production at least until 2025. Is this circuit still a good choice or are there newer ones? Requirements: 8 x 0.5A output at 10-17V supply voltage and operating temp -30 to +50C. Short circuit protection and fault status reading needed.
Hi Dirk,
The MC33879A does have an Active status as can be seen on the product website and is recommended for new designs. Currently there are no plans to discontinue it.
Tomas
Hi Dirk,
Tomas
Hi Tomas,
that sounds good. Just wanted to check since the device is from 2006 and Long Term Availability guarantees 15 years => 2021.
Best
Dirk
