MC33771C Identify the number of Cids before initialization
1,342 次查看
zhuangfei
Hi:Sir
I want to identify the number of Cids before initialization.
when i read the register INIT which CID is not exit before initialization, i will get what data? For example, i only use 4 MC33771Cs, then i read the fifth CID. I will get what data?
标记 (1)
1,336 次查看
TomasVaverka
Please see below an extract from the datasheet. I suppose this answers your question.
Tomas
1,329 次查看
zhuangfei
Hi:Tomas
Thank you very much for your reply.
This one does solve my question, I just got the MC33771C chip manual, the old version I looked at before, as you said, I can find this.
However, I found a new question, can MC3371C dynamically identify the number of CIDs through software during the initialization process? The INIT register can only be programmed once, how can I determine which node's INIT[TPLx_TX_TERM] register should be set to 1 if I don't know which node is the last one.
Looking forward to your reply.
