Currently I am developing PT2001 IC.
I want to control PT2001 IC directly.
However, I can't find a data sheet for SPI communications.
Where can I find it?
Solved! Go to Solution.
Hi Jang,
All details regarding the SPI communication can be found in the PT2001 full datasheet which is available on DocStore:
https://www.docstore.nxp.com/products/product-hierarchy?query=PT2001
…and requires an NDA (Non-Disclosure Agreement). If your company has not signed the NDA with NXP yet, please create a new case for my colleagues who are in charge of the NDA process and can eventually help you with that.
Tomas
Hi Jang,
Tomas
I have solved some of the problems.
Referencing the PT2000 IC Datasheet, I am solving the problem.
However, it has not been able to resolve the continuous interrupt.
The corresponding interrupt is as follows.
1.DRV IRQ
-Uv VCCp
-Over Temp
2. Checksum IRQ
Where can I check if the corresponding interrupt occurs?
