How to bypass the impact of VCORE_FB_UV, VAUX_UV and VCCA_UV when using SBC4500
Search instead for
xinguang_wang
when I using FS4500CAE chip to manage S32K144 power fault, I encountered some questions as below.
  1. This has three errors which is VCORE_FB_UV, VAUX_UV and VCCA_UV. Due to these errors, the RSTB and FS0B  pins are low, ABIST1 is not OK as well. And I can't enter INIT_FS mode to bypass the impact of them.
  2. When I enter Debug mode(Of course, there are errors above), and main state machine is normal mode, the register states about CAN has no error, but I can't get message from can box using laptop. My same program works OK on another board which has the same MCU pin about CAN, I wonder to know why it doesn't work.
I'm very appreciated if you could give me any suggestions about it.
Thanks a lot!
Xinguang
Tags (2)
guoweisun
Please provide your schematic of SBC ?
xinguang_wang
Hi G.w.
my schematic of SBC is as below:
Is there any problem?
Thanks a lot and Best Regards!
Xinguang
guoweisun
I attached the schematic for your reference,please also tell your phone number!
xinguang_wang
Hi G.w.
Thanks you very much, my phone number is 17737597085.
Best Regards!
Xinguang
