FlexGUI "Use this configuration and do not ask again" doesn't work
1,075 次查看
jfix
I'm using FlexGUI to program my PMIC. I'm setting it up for use in production.  I would like to take advantage of the "Use this configuration and do not ask again" that appears at the bottom of the Launcher.  This will eliminate an extra click for the operator.  However, it doesn't seem to work.  What am I missing?
1,062 次查看
ErikaC
Please try to run the restore defaults that are in the same folder and try again, I already tested it and it works fine for me.
I hope it helps.
Best regards.
1,063 次查看
ErikaC
I hope it helps.
Best regards.
