FS26 TRK2 UV fault
FS26 TRK2 UV fault
676 次查看
hbsantos
I'm using FS26 with s32k344 and the FS_OVUV_REG_STATUS register shows undervoltage on TRK2 through SPI. But I don't have any load on TRK2, just two capacitors: 2.2uF/50V and 100nF/100V. I measured the TRK2 voltage with a multimeter and oscilloscope and it's equal to 5V, that is, it's correct. Could someone help me to solve this?
标记 (5)
604 次查看
RafaR
Hi hbsantos
Can you show me your schematic?
I want to see those capacitors, your problem sounds like you're affected by a voltage divider so I want take a look your connection
If you have any problems sharing your scheme through the community, I recommend opening a ticket on our support page so we can talk more confidently.
I will be waiting for your response
Have a great day and best of luck.
605 次查看
RafaR
Hi hbsantos
647 次查看
RafaR
I am starting to work on your case, I will contact you soon.
