FS26 TRK2 UV fault
FS26 TRK2 UV fault
hbsantos
I'm using FS26 with s32k344 and the FS_OVUV_REG_STATUS register shows undervoltage on TRK2 through SPI. But I don't have any load on TRK2, just two capacitors: 2.2uF/50V and 100nF/100V. I measured the TRK2 voltage with a multimeter and oscilloscope and it's equal to 5V, that is, it's correct. Could someone help me to solve this?
Tags (5)
RafaR
Hi hbsantos
Can you show me your schematic?
I want to see those capacitors, your problem sounds like you're affected by a voltage divider so I want take a look your connection
If you have any problems sharing your scheme through the community, I recommend opening a ticket on our support page so we can talk more confidently.
I will be waiting for your response
Have a great day and best of luck.
RafaR
Hi hbsantos
RafaR
I am starting to work on your case, I will contact you soon.
%3CLINGO-SUB%20id%3D%22lingo-sub-2077094%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFS26%20TRK2%20UV%20fault%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2077094%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EI'm%20using%20FS26%20with%20s32k344%20and%20the%20FS_OVUV_REG_STATUS%20register%20shows%20undervoltage%20on%20TRK2%20through%20SPI.%20But%20I%20don't%20have%20any%20load%20on%20TRK2%2C%20just%20two%20capacitors%3A%202.2uF%2F50V%20and%20100nF%2F100V.%26nbsp%3BI%20measured%20the%20TRK2%20voltage%20with%20a%20multimeter%20and%20oscilloscope%20and%20it's%20equal%20to%205V%2C%20that%20is%2C%20it's%20correct.%20Could%20someone%20help%20me%20to%20solve%20this%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2081988%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20FS26%20TRK2%20UV%20fault%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2081988%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20hbsantos%3C%2FP%3E%0A%3CP%3ECan%20you%20show%20me%20your%20schematic%3F%3C%2FP%3E%0A%3CP%3EI%20want%20to%20see%20those%20capacitors%2C%20your%20problem%20sounds%20like%20you're%20affected%20by%20a%20voltage%20divider%20so%20I%20want%20take%20a%20look%20your%20connection%3C%2FP%3E%0A%3CP%3EIf%20you%20have%20any%20problems%20sharing%20your%20scheme%20through%20the%20community%2C%20I%20recommend%20opening%20a%20ticket%20on%20our%20support%20page%20so%20we%20can%20talk%20more%20confidently.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%20will%20be%20waiting%20for%20your%20response%3C%2FP%3E%0A%3CP%3EHave%20a%20great%20day%20and%20best%20of%20luck.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2078666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20FS26%20TRK2%20UV%20fault%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2078666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20starting%20to%20work%20on%20your%20case%2C%20I%20will%20contact%20you%20soon.%3C%2FP%3E%3C%2FLINGO-BODY%3E
