Customer confirms about correct unused pin termination, if LICELL pin is not used.
Which one is correct capacitor either 22nF or 220nF for unused LICELL?
Hardware Design Guide Lines Rev 2.0 is recommended to connect 22nF to GND, but schematic shows 0.22uF.
(Typical application Diagram in datasheet rev7.0 is placed 0.22uF on LICELL pin.
If no used, please connect 220nF.
