Can I modify the application schematic of a MC33772BSP1AE to be equal to a MC33772BTC0AE?
已解决
跳至解决方案
1,351 次查看
AleSanders
Hi Community,
I was wondering if I could use a #MC33772BSP1AE (predisposed for cell monitoring) as a current sense IC as it is the #MC33772BTC0AE (since the latter it is not available in the market right now) by just using the specific application schematic provided at pg. 122 of the datashee
Thanks in advance.
1 解答
1,341 次查看
JozefKozon
Hi Alessandro,
unfortunately no. If you need only the current sense, you cannot use the #MC33772BSP1AE. You would need to use minimally 3 Cells with this BCC (Battery Cell Controller). But you can use our newer MC33772CTC0AE.
Our authorized distributor MOUSER has 500 of the MC33772CTC0AE in stock.
https://eu.mouser.com/ProductDetail/NXP-Semiconductors/MC33772CTC0AE?qs=iLbezkQI%252BshD5dQy1N0QDQ%3...
With Best Regards,
Jozef
在原帖中查看解决方案
2 回复数
1,342 次查看
JozefKozon
Hi Alessandro,
With Best Regards,
Jozef
1,337 次查看
AleSanders
Thanks for the fast answer! Have a nice day
