CANNOT Flash Program to MPC5775B
jim_duan
cannot flash to MPC5775BE-416DS daughter card!
"Warning: Device is not detected or may be censored. Please enter password in GDB server parameters with debug
configurations using the flag -uncensorpassword=n, then restart the debug session."
S32 Design Studio for Power Architecture   Version: 2.1    Build id: 190624
davidtosenovjan
Hi, I believe it the same issue as in the similar case you have submitted recently.
Could you possibly share the solution for possible readers of this thread? Thanks
An error has occurred when reading existing sub-variable "Language_PG_Configuration"; see cause exception! The type of the containing value was: extended_hash+string (lithium.coreapi.webui.template.models.NamedValueByNameTemplateModel wrapped into f.e.b.StringModel) ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign redirect_lingo_page_url = web... [in template "language_macro_header.ftl" at line 173, column 1] - Reached through: #include "language_macro_header.ftl" [in template "Language_translator_Dashboard" at line 3, column 1] ----
