AFT05MS003N 70-80MHz Specs
552 次查看
dave_harmonjr
Is there anyway I can get the input impedance and output impedance at 74MHz? I downloaded the ADS model and tried to replicate the specs for the 135MHz specs listed in the datasheet and could not get the same results as listed. I wanted to try to do that to get confidence in the results. I used the ADS Load Pull Design Guide to try to get those parameters.Unfortunately they were way too off to seem like the model matched up with the datasheet.
0 回复数
