qoriq ddr3 with ECC
Search instead for
qoriq ddr3 with ECC
jagxin
Hello everyone
             If we are using ddr3 with ECC where should the chip placed in the daisy chain first from the controller  in between on the last near to termination
if we place first on the daisy chain termination is very far and SI is not that good
whether more care is required for ECC or it Can de given least importance and can be placed first on the Daisy chain
regards
AGXIN.J
Bulat
It does not matter where the ECC chip is placed in the fly-by chain, you can put it first, last or somewhere in between. Note for example that typical DDR3 DIMM has ECC chip in the middle.
Bulat
